88W8997 module command timeout issue (interface PCIE+UART, Host: iMX8MQ) - reopen
yao_feng
The FW crashed issue is still exist in Generic_PCIE-WLAN-UART-BT-8997-LNX_6_6_3-IMX8-16.92.21.p119.2-16.92.21.p119.2-MM6X16437.P3-GPL.
follow previous case:
https://community.nxp.com/t5/Wireless-Connectivity/88W8997-module-command-timeout-issue-interface-PC...
and reopen by this case.
@ArthurC
@Christine_Li
88W8997
Christine_Li
Hi, @ArthurC
Thanks for your quick reply.
We have Linux 5.15.71_2.2.2, Linux 5.15.71_2.2.1 and Linux 5.15.71_2.2.0 prebuilt image versions on our website.
Please share the exact version of the 8MQ pre-built image that you have flashed to avoid any discrepancy.
Christine.
ArthurC
Hello @Christine_Li,
Please use command "dkpg install" to install the network manager package in official prebuild image.
And then nmcli will be working.
Please use the prebuilt image "imx-image-full-imx8mqevk.wic" to test.
Thank you.
Christine_Li
Hi, @ArthurC
We checked the zip file shared by the customer, it only contains .deb files, we need an executable nmcli binary which we can directly copy to 8MQ and use. Can you please share it to us?
Also, We have Linux 5.15.71_2.2.2, Linux 5.15.71_2.2.1 and Linux 5.15.71_2.2.0 prebuilt image versions on our website. Please share the exact version of the 8MQ pre-built image that you have flashed to avoid any discrepancy.
Christine_Li
Hi, @ArthurC
Thanks for your reply.
Sure, We will use the given nmcli to have a try on our local side.
Christine.
ArthurC
We are using (standalone prebuilt image + your yocto build nmcli binary) to test.
But our EVK's PMIC (pfuse100) is unexpected broken during the test procedure.
Probably it was purchased for long time ago. It can't boot anymore.
So we can't provide the results for you.
The yocto build nmcli binary is as attached.
Please help to use it to check.
Thank you
Christine_Li
Hi, @ArthurC
1. If you have complete BSP(i.MX8MQ-EVK prebuilt image + nmcli package) then please provide us the full BSP image.
2. If you are using the (standalone prebuilt image + your yocto build nmcli binary) then please provide us the nmcli binary to install in our i.MX8MQ-EVK and also provide the steps which you followed to install the nmcli binary in our i.MX8MQ-EVK.
Christine.
ArthurC
Hello @Christine_Li ,
We use nmcli.
Installed by ourselves.
Christine_Li
Hi, @ArthurC
Thanks for your feedback.
I know you mentioned that you are using nmcli on your 8MQ board. And also you mentioned same issue can be reproduced on our 8MQ-EVK + our prebuilt image.
Can you please help to confirm on our 8MQ-EVK + our pre-built  image what did you use?
nmcli or wpa_supplicant ?
Christine.
ArthurC
Yes, will provide the setup flow to you based on EVK later.
Actually, there are a lots of unexpect risks during shipping the product to you.
So dealing with issue based on EVK will be better.
Thank you for your help.
Will provide to you next Thursday.
Christine_Li
Hi, @ArthurC
We are still trying to reproduce on our locally. Thanks for your understanding.
Christine.
Christine_Li
Hi, @ArthurC
I am so sorry, I am from TIC wireless connectivity team. According to our company's policy, I am only allowed to provide online support for mass market customers. So I am not allowed to have a business trip to your office.
So please help to prepare the board and send to us so that we can capture requested logs and move forward. We have tried one week to try to reproduce, but unfortunately we could not reproduce locally right now. So we sincerely ask for your help. Please understand us. Without your help and the logs, we stuck here, could not move forward.
Christine.
ArthurC
Have you got any chance to prepare the test environment(your Image / some test script) on the board?
-> No, I need to deal with lots of other work assigned by Tony.
Have you sent out the board to me?
-> No, because there are lots progresses needed to follow in GIGABYTE.
Please let me know the status of delivery so that I can track where it is.
Could you have a business trip to our office to capture the logs locally without product sending?
Christine_Li
Hi, @ArthurC
Christine.
Christine_Li
Hi, @ArthurC
Thank you for the feedback.
I saw your supervisor has approved to send us one of your board.
Have you got any chance to prepare the test environment(your Image / some test script) on the board? Please help to sync the test steps with your previous test and make sure we can reproduce on this board with less operations.
Please let me know when can you send out and share me the delivery number so that we can track further.
Thanks for your efforts and corporations.
Christine.
ArthurC
Can you please help to get the answers of the below queries?
1. Is DUT BT is mater or slave?
-> Master.
2. Is DUT BT is source or sink?
-> Source.
3. Which BT reference device(remote BT headset) are you using for the test?
-> FiiO BTR3
https://www.fiio.com/btr3K
Christine_Li
Hi, @ArthurC
1. Is DUT BT is master or slave?
3. Which BT reference device(remote BT headset) are you using for the test? Can you please help to provide model and version?
Christine.
Christine_Li
Hi, @ArthurC
Christine.
Christine_Li
Hi, @ArthurC
Sure, I can send this request email.  Thank you so much for your help.
Christine.
ArthurC
I don't have permission about sending our product to you.
Please send mail to my supervisor according the following mail address:
tony.ku@gigabyte.com
Christine_Li
Hi, @ArthurC
Yes, I know. During the test, we keep the Wi-Fi connection in 2.4G, and the PC which is doing iperf also connected to the same 2.4G AP.  Bluetooth is playing A2DP music under 3M baud rate.
So please help also to check on your side whether is possible to send one of your board with your setup, so that we can reproduce and capture related logs. Without your help, it is too difficult for us to proceed further.
Christine.
ArthurC
Please make sure the Wi-Fi connection is under 2.4 GHz & play bluetooth audio in the same time in 88W8997.
If it is in 5GHz. The issue will not be occured.
Please fix the AP is 2.4GHz or set PC working under 2.4GHz in direct connection.
