Hi NXP,
Our customer wants to use 88MW322-A0-NXUE/AZ on Semi Drive E3430.
Do you already have drivers that customers can use directly?
The OS is FreeRTOS V10.2.1
Thank you!
Lewis
Solved! Go to Solution.
That is correct. 88MW320 MCUXpresso SDK is compatible with your device.
Best regards, Daniel.
I’d recommend you to use the 88MW320 MCUXpresso SDK. You can download it here.
I hope this helps.
Hi Daniel,
Thank you for your prompt reply!
Do you mean the 88MW320 MCUXpresso SDK is compatible with 88MW322?
Can custormer use it on 88MW322 directly?
Lewis
Hi Daniel,
Thank you for your significant help!
Hope you have a wonderful day!
Lewis.
