DAC with DMA on Vybrid VF65GS10
808件の閲覧回数
muhammad_qasim
I am working on DAC module for Vybrid VF65GS10 and successfully done with
non- buffered support [DAC0_STATCTRL = 0x0000E002]
Buffered support [DAC0_STATCTRL = 0x0F01E002; Set DACSWTRG bit in loop to advance read pointer]
I have tried to use DAC with DMA but no success. [I have successfully used DMA with Serial].
Here is my settings for DAC
[DAC_STATCTRL = 0x0080C702]
DAC0 interrupt is enabled [87]
Here is my settings for DMA
DMA0
DMA0_MUX1
Peripheral ID: 32
DMA Channel: 16
If I manually set DMA_TCD_CSR[START] bit during debugging then data is appeared in data register of DAC. otherwise no data is visible on DAC Data Register (Buffer 0).
What is wrong with my configurations.
3 返答(返信)
575件の閲覧回数
alejandrolozan1
Attached you can find a very simple example I created. It is using a circular buffer for the DMA. PDB to update the DAC pointer.
The example is in IAR using as reference the vybrid examples VYBRID_SAMPLE_CODE_SBCH found at:
http://www.freescale.com/webapp/sps/download/license.jsp?colCode=VYBRID_SAMPLE_CODE_SBCH&location=nu...
I hope that helps.
575件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you   attend this case?
575件の閲覧回数
alejandrolozan1
I am working with the customer already. The customer needs an example with no OS.
Alejandro
