When I boot T4240QDS for SMP mode, it sometimes(1/10) happen L3 error(CPC1_CPCERDET=0x60). my boot step is below:
1. core0 boot up successfully and L2/L3 both off
2. core0 configure spin table (cache inhibit ) and boot page
3. core0 reset secondary cores and secondary cores enter spin loop successfully
4. core0 enable L2/L3 with error check (CPCCSR0=0xc0000000, CPCERRINTEN=0)
5. core0 setup secondary cores spintable->addr
6. secondary cores exit spin loop and goto their spintable->addr, SMP successfully.
However, sometimes, some one of secondary cores will randomly fail by a machine check event. I attached with CodeWariorr could see that CPC1_CPCERDET=0x60 and the failed core happened machine check(MCSSR0=0x23e034, MCSRR1=0x30)
If without CPC error check (CPCCSR0=0x80000000) at step 4 will not reproduce it
If enable CPC before reseting secondary cores, i.e. switch step 3 and 4, will not reproduce it
my question:
a. CPCERRINTEN=0, even happen CPC error, why it will cause machine check?
b. I see in uboot core0 firstly enable L2/L3 then reset secondary core, Is this the only correct flow?
Solved! Go to Solution.
Sorry for delayed response to this.
This question is already answered factory engineering team via direct support ticket to online technical support.
Shortly - factory engineering team suggests enabling L2/L3 before enabling secondary cores.
Alexander
TIC
Alexander
TIC
