Qoriq t1024 bareboard programming guide
1,275 次查看
leventkarakaya
Hello
Is there any programming guide, manual, or tutorial for programming bareboard applications on Qoriq t1024 processor?
7 回复数
995 次查看
ufedor
Do you mean application development or on-board flash programming?
995 次查看
slimSHA
can u please tell how to do onboard flashing
995 次查看
leventkarakaya
I mean bareboard application development. I dont want to use Linux. Instead, I will program the flash. It was named as Bareboard application in CodeWarrior. But, I could not find any programming guide or tutorial on how to program bareboard application. Where can I find such materials?
995 次查看
ufedor
Information about bareboard applications is provided in the CodeWarrior Development Studio for Power Architecture Processors Targeting Manual (\CW_PA_v10.5.1\PA\Help\PDF\Targeting_PA_Processors.pdf) and, also, CodeWarrior installation contains Bareboard Example project.
995 次查看
leventkarakaya
Thank you for information.
Document contains information on debugging, and creating projects in CWPA. But I am looking for a programming guide for bareboard applications. For example, how can I create an ethernet TCP socket?, how can I communicate with CPLD?, etc.
Do you know such a document?
995 次查看
ufedor
There is no such guide.
Possible reference could be U-Boot source code.
995 次查看
leventkarakaya
Thank you for your help.
