I am working on t4160 board and I want to initializae DDR and test memory. I followed this document and I not clear that.
Will you please provide the steps or verify my steps right or wroung?
Reference Link:
http://cache.freescale.com/files/training/doc/ftf/2014/FTF-NET-F0137.pdf
Steps:
1. Open CodeWarrior Flashprogrammer
2. Go to Hardware Diagnostics Action for DDR initialization
Run->Debug Configuration->Edit Harware->Initialization File->select T4160qds_init_Core.tcl
3. Create a New Task
Click-> Create a New Task->select Hardware Diagnostic as Task Type -> Finish
4. Go to Hardware Diagnostics Action for Memory Test
Select Memory Test->check(Walking 1's, Bus Noise and Address)
5. Stat run
6. Once done the ddr initialization open debug shell and run the following commands,
"display 0x000 20"
Thanks, VinothS
解決済! 解決策の投稿を見る。
The Hardware Diagnostics Actions (including Memory tests) are described in detail in the CodeWarrior Development Studio for Power Architecture Processors Targeting Manual (Targeting_PA_Processors.pdf), 11.3 Hardware diagnostics.
Hi Ufedor,
Thank you for your reply
Regards, VinothS
