I have purchased TPM sensor IC with following part number-
F874B11 XCBNA
Please provide pressure range and also i'm receiving 0x1FE for pressure more than 40psi.
Thank you
The device part that you are referring is the FXTH8705116T1.
In this case, its pressure range is 100-450 kPa.
Please find the datasheet attached to this response.
David
never-displayed
