Pressure sensor
Pressure sensor
803件の閲覧回数
prasadbangar
Hi sir,
I have purchased MPXH6300AC6T1 Pressure sensor.My application is for measuring tyre pressure and i want to insert the sensor inside tubeless tyre which will be connected to the rim, the data is wireless transmitted and received through RF module and further processed by micro-controller,is MPXH6300AC6T1  suitable for placing it inside the Tyre and giving the precise results, if not
please suggest me some other IC which can  suit my application more focusing on placing sensor inside the tyre.
Thank you.
661件の閲覧回数
Joshevelle
Senior Contributor I
Hello Prasad,
Yes, you could use the MPXH6300A, however we have a dedicated product for this specific application, the FXTH870911D which has a pressure sensor, an accelerometer, RF transceiver and an S08 MCU integrated in a single 7x7mm package.
I would recommend you to take a look at the following demonstration video:
http://www.freescale.com/webapp/video_vault/videoSummary.sp?code=TPMS-DISPLAY-DEMO
Hope it helps.
-Josh
