NTM88H135ST1 SPI communication
ankit2631
i was thinking of using NTM88H135ST1 for my TPMS application but while going through the datasheet, in General Description section it is stated that it supports Client SPI. does that, mean it works only in client mode i.e., Master mode. I want to know that can I use it as a slave also? Because my application requires it to work as a SPI slave
TomasVaverka
Hi Ankit,
Yes, for an example of sensor data transferred via SPI to a host MCU, you can have a look at the below demo package which contains demo projects and a user guide:
https://www.nxp.com/products/sensors/pressure-sensors/tire-pressure-monitoring-sensors/ntm88-highly-...
Tomas
