Measuring water level in the tank
2,407件の閲覧回数
PA3040
Dear All
Please advice me what is the most suitable sensor to measure water level and put the result in the LCD display
Water tank 500L
fixed on root top 6M
I would like to connect the sensor height from the ground about 2M
My Tank height 1M
width 1M
Pipe diameter 1.25cm ( hose connected to tank )
Please advice
Thanks in advance
697件の閲覧回数
TomasVaverka
The following application notes might help you to select a suitable device.
AN1950: Water Level Monitoring
http://www.freescale.com/files/sensors/doc/app_note/AN1950.pdf
AN1516: Liquid Level Control Using a Pressure Sensor
http://www.freescale.com/files/sensors/doc/app_note/AN1516.pdf
Tomas
