MPXV5010DP replace MPXV5010GP
yangzhao1
Our design use mpxv5010GP. Now because we do not have any in stock.So can we use Mpxv5010DP replace ?
And is there some different about the schematic and software ?
TomasVaverka
Yes, the MPXV5010DP can easily replace the MPXV5010GP, the only difference is the package (P2 pressure port vs. vent hole at the bottom of the chip):
Tomas
yangzhao1
As my understanding , if we use MPXV5010DP  replace MPXV5010GP,we do not change schematic and PCB layout.
MPXV5010DP can use in Differential or Gauge Configurations. How to use it in Gauge Configuration?
We can only use one port as follow to in Gauge configuration?
TomasVaverka
They are fully pin to pin compatible => no change in schematic/layout needed.
Yes, you will only use the P1 port, P2 port will be left open.
Tomas
