Incorrect WHO_AM_I from MMA8652FC
24,665件の閲覧回数
mitek
i have 2 modules - MMA8652FC and MMA8653FC (and MMA865X)
WHO_AM_I register on both modules = 0x5A but as described in datasheet must bs 0x4A and 0x5A.
Also SensorToolbox display MMA8653FC on both modules.
Mitek
10 返答(返信)
23,879件の閲覧回数
TomasVaverka
Hello Mitek,
I have just tested both the MMA8652FC and MMA8653FC accelerometers using the Sensor Toolbox GUI and as you can see in the attached file both have the correct ID (0x4A for the MMA8652FC and 0x5A for the MMA8653FC).
Could you please post here your print screens of the Sensor Toolbox GUI similar to mine?
Tomas
23,879件の閲覧回数
mitek
Hello Tomas,
Thanks for your replay.
First module MMA8652FC
SN:00847 700-76802_A SCH-76802_A OF:626548
Second module MMA8653FC
700-76803_A SCH-76803_A SN:00453 OF:626549
Also I make simple I2C program on external processor and read 5A from 0D register on both modules.
Mitek
P.S. Also you can see bug on this screen in bottom panel - display 3A as data and in bits state
23,879件の閲覧回数
TomasVaverka
Mitek,
Thanks for the screen shots.
Please look at the top side of both devices through the magnifier and let me know what you are seeing. Is there 652 (denotes the MMA8652FC), 653 (MMA8653FC) or anything else as the first number?
Tomas
23,879件の閲覧回数
mitek
Ups, not a correct replay.
Hello Tomas, I make zoomed photo for both modules.
Normal MMA8652 chip must be 652 mark but this chip unknown.
Mitek
23,879件の閲覧回数
TomasVaverka
Mitek,
I am still investigating it, actually my MA8652FC accelerometer is marked as E13 (your is E10) and its ID is correct (0x4A). I will get back to you as soon as I know more.
Tomas
23,879件の閲覧回数
mitek
Thanks Tomas
23,879件の閲覧回数
TomasVaverka
Mitek,
Both MMA8652FC accelerometers we have been working with (E10 – yours, E13 - mine) seem to be engineering samples.
I would recommend ordering free samples of the MMA8652FC by clicking on the “Sample” button on this website and replace the original engineering sample using this new part.
If you want to return the complete LFSTBEB865x kit, please follow the standart warranty policy.
Sorry for any inconvenience it may cause.
Tomas
23,879件の閲覧回数
mitek
Hello Tomas,
I desoldering E10 and mount 652 from Freescale samples J
Now all perfect.
Problem resolved.
Mitek
23,879件の閲覧回数
TomasVaverka
Glad to hear it has been solved by replacing the part.
Have a nice weekend and thanks for using our community.
Tomas
23,878件の閲覧回数
mitek
Hi Tomas,
I already add serial numbers and it looks as normal for 52 and 53
Best reagards
Mitek
