Hello, I debug why MMA8452Q motion when the output is not interrupted? INT1 no change
829 次查看
jackrong
Initialization. System 2.8V power supply
void Init_MMA8452()       //initialization
        Single_Write_MMA8452(0x2A,0x18);  //100HZ  ODR
     Single_Write_MMA8452(0x15,0xD8);  // The motion detection threshold set, X, Y axis
     Single_Write_MMA8452(0x17,0X30);  //Set the threshold for the 48 motion detection
     Single_Write_MMA8452(0x18,0x0A);  // 100 milliseconds to shake the time
        Single_Write_MMA8452(0x2D,0x04);   // Set motion interrupt
        Single_Write_MMA8452(0x2E,0x04);   //Set the interrupt pin for INT1 motion
        Single_Write_MMA8452(0x2A,0x19);   // Active mode
4 回复数
554 次查看
TomasVaverka
Hi Jack,
It is hard to say where the problem might be without seeing your complete source code/schematic.
I would recommend looking at the attached simple example code for motion detection based on the AN4070 and another thread where a similar problem was discussed.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
554 次查看
jackrong
The problem is solved. thank you!
554 次查看
jackrong
hello!Shaking, respectively, read X, Y, Z axis data have changed but the fracture INT1 no level change
void exint0() interrupt 0 //INT1 Interrupt entry (INT1 external 10K pull up resistor)
Single_Read_MMA8452(0X0C);
SeriPushSend('O');
SeriPushSend('K');
SeriPushSend('?');
Single_Write_MMA8452(0x2C,0x01); //Low drop along trigger
void main()
delay(250);
init_serialcom();
inti_time0();
Init_MMA8452();
count=0;
while(1)
if(count==100) //Read three axis data per second
count=0;
Multiple_Read_MMA8452();
display_x();
display_y();
display_z();
554 次查看
jackrong
hello! Shaking, respectively, read X, Y, Z axis data have changed but the fracture INT1 no level change
     Single_Read_MMA8452(0X16);
