Development on NTM88 using CodeWarrior IDE: Flash Programming and Source Code Management
659件の閲覧回数
OzEl
I am currently working on NTM88 utilizing CodeWarior 11.1 IDE, and I have successfully managed to program and compile my project. However, my team mate also needs to program other devices, and I am wondering if there is a tool available instead of CodeWarior that would allow them to program the NTM88 without requiring access to the source code project within the IDE (I want to provide them only the  .s19 file)
Additionally, I would like to know if you have any recommendations regarding which files should be kept in the source code repository. For example, what files should be included in the repository and which files should be excluded using the .gitignore function?
We are using  https://www.nxp.com/products/power-management/motor-and-solenoid-drivers/powertrain-and-engine-contr...
ラベル(2)
642件の閲覧回数
TomasVaverka
Discussed internally (Case #00531993).
