Accelerometer: MMA8491 Breakout Board
The MMA8491Q is a low voltage, 3-axis low-g accelerometer housed in a 3 mm x 3 mm QFN package. The device can accommodate two accelerometer configurations, acting as either a 45° tilt sensor or a digital output accelerometer with I2C bus.
     • As a 45° Tilt Sensor, the MMA8491Q device offers extreme ease of implementation by using a single line output per axis.
     • As a digital output accelerometer, the 14-bit ±8g accelerometer data can be read from the device with a 1 mg/LSB sensitivity.
The extreme low power capabilities of the MMA8491Q will reduce the low data rate current consumption to less than 400 nA per Hz.
Here is a Render of the MMA8491 Breakout Board downloaded from OSH park:
Layout Design for this board:
If you're interested in more designs like this breakout board for other sensors, please go to Freescale Sensors Breakout Boards Designs – HOME
%3CLINGO-SUB%20id%3D%22lingo-sub-1128025%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAccelerometer%3A%20MMA8491%20Breakout%20Board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128025%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EThe%20MMA8491Q%20is%20a%20low%20voltage%2C%203-axis%20low-g%20accelerometer%20housed%20in%20a%203%20mm%20x%203%20mm%20QFN%20package.%20The%20device%20can%20accommodate%20two%20accelerometer%20configurations%2C%20acting%20as%20either%20a%2045%C2%B0%20tilt%20sensor%20or%20a%20digital%20output%20accelerometer%20with%20I2C%20bus.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%A2%20As%20a%2045%C2%B0%20Tilt%20Sensor%2C%20the%20MMA8491Q%20device%20offers%20extreme%20ease%20of%20implementation%20by%20using%20a%20single%20line%20output%20per%20axis.%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%A2%20As%20a%20digital%20output%20accelerometer%2C%20the%2014-bit%20%C2%B18g%20accelerometer%20data%20can%20be%20read%20from%20the%20device%20with%20a%201%20mg%2FLSB%20sensitivity.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20extreme%20low%20power%20capabilities%20of%20the%20MMA8491Q%20will%20reduce%20the%20low%20data%20rate%20current%20consumption%20to%20less%20than%20400%20nA%20per%20Hz.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHere%20is%20a%20Render%20of%20the%20MMA8491%20Breakout%20Board%20downloaded%20from%20OSH%20park%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8491_Top_Bottom.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8491_Top_Bottom.jpg%22%20style%3D%22width%3A%20939px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F50609i4883181DBB8DAC6A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MMA8491_Top_Bottom.jpg%22%20alt%3D%22MMA8491_Top_Bottom.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMMA8491_Top_Bottom.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELayout%20Design%20for%20this%20board%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8491_Top_Bottom_Copper.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MMA8491_Top_Bottom_Copper.jpg%22%20style%3D%22width%3A%20753px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F50600i1E96E2486940B66B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MMA8491_Top_Bottom_Copper.jpg%22%20alt%3D%22MMA8491_Top_Bottom_Copper.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMMA8491_Top_Bottom_Copper.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20you're%20interested%20in%20more%20designs%20like%20this%20breakout%20board%20for%20other%20sensors%2C%20please%20go%20to%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103424%22%20target%3D%22_blank%22%3EFreescale%20Sensors%20Breakout%20Boards%20Designs%20%E2%80%93%20HOME%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128025%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎02-03-2026 05:16 PM
Updated by:
