How can I use SE050 with STM32 , can I get MW library files compatible with STM32?
1,675件の閲覧回数
Poonam123
How can I use SE050 with STM32 , can I get MW library files compatible with STM32? In MW the supported files are compatible for NXP controllers
5 返答(返信)
174件の閲覧回数
Alon1
did you succeed?
any code examples will be appreciated.
933件の閲覧回数
Spri
 Hi @Poonam123 , I have similar task to interface the se050 with stm32, are you able to mange porting of mw?
Can you help me in it?
Priyank.
1,670件の閲覧回数
Kan_Li
Hi @Poonam123 ,
So far the MW just supports NXP MCUs, but we also provide a porting guide for your case. Please kindly refer to https://www.nxp.com/docs/en/application-note/AN12448.pdf for details.
Hope that helps,
Kan
1,661件の閲覧回数
Poonam123
Hi , Is it possible to operate se050 with simple I2C by configuring apdu? I want to use SE050 without use of library .
1,655件の閲覧回数
Kan_Li
Hi @Poonam123 ,
If you just use several commands to communicate with SE050, I would recommend you configure the APDU commands with the help of MW, please kindly refer to "simw-top/doc/demos/se05x/se05x_GetAPDUBuffer/Readme.html" for details.
If you are just concerning with the memory consumption of the MW, we provide a tiny version of package instead, please kindly refer to https://github.com/NXPPlugNTrust/nano-package for details.
Hope that helps,
Kan
