h.264 specifications in S32V234
2,847 次查看
mach_lee
Hello..?
I have some doubt while reading the datasheet of s32v234 ( https://www.nxp.com/docs/en/data-sheet/S32V234.pdf ).
The document (page 7) says that s32v234 support H.264 video decoder (8/10/12-bit), High-intra
and constrained baseline formats and H.264 video encoder (8/10/12-bit), I-frames only.
Does that means the h.264 streams from s32v234 don't have p-frames or b-frames at all..?
If it does, h.264 video codec is different from i.mx6q or others from NXP. am I right..?
Please give me any answer or hint.
Thank you.
标记 (2)
2,419 次查看
KushalShahNXP
Hi Mach,
I recommend you to refer Features sections of chapter 60 and 61 the Reference Manual. It will help you answer all your questions.
S32V234 RM can be found here: https://www.nxp.com/docs/en/reference-manual/S32V234RM.pdf
Please let me know. If you have further questions.
Kushal
2,418 次查看
mach_lee
Thank you Shah,
The Reference Manual says clearly that S32V234 supports I-Fame Only encoding.
2,420 次查看
KushalShahNXP
Hi Mach,
Kushal
