use canfd by different clock source
486 次查看
78621251
when i use FLEXCAN_CLK_SOURCE_SOSCDIV2 clock source,canfd is normal. Then i exchange the clock source to FLEXCAN_CLK_SOURCE_SYS, Corresponding,i config CBT,and FDCBT by different clock source frequency.which else register should config too ?
470 次查看
Robin_Shen
Seems that you are using old version SDK. Why not direct select it with Processor Expert or S32 Configuration Tool.
PE clock source Processor Expert.pngPE clock source S32 Configuration Tool.png
Robin
