Hello
Related to Flash memory , I found a conflict(maybe) need to support
In S32K14x Seriex Cookbook.pdf ,I found description as below:
It means ---> Value 1 means Enable , Value 0 means Disable;
But in S32K144_RM.pdf ,I found that
the conflict is :Value 0 means enable, Value 1 means disable
So I am confused about this ,which is correct ? or if my undersood is wrong?
Thank you.
best regards
The current reference manual rev.9 is correct.
Value 0 means enable, Value 1 means disable.
And the default out-of-reset configuration of OCM1 is 0b00 that means enabled.
It was the other way round on the first S32K144 maskset 0N77P.
Thank you for pointing this out.
