s32k144 is used to debug a new motor
zhouqicheng
When using s32k144 to debug a new motor, and in closed-loop, the speed runs off, and drvFOC.iDQReqInLoop.fltArg2 becomes negative. However, when drvFOC.iDQReqInLoop.fltArg2 is multiplied by 0.35, it can run normally. How should I adjust the speed loop, Current loop or observer
_Leo_
Thank you so much for your interest in our products and for using our community.
You can refer to the app note Motor Control Application Tuning (MCAT) Tool for 3-Phase PMSM (AN4642), which will help you with parameter tuning when proposing a new motor.
Hope it helps you.
Have a nice day!
