port control register base address
3,148 次查看
weiqianglin
I used S32k144 chip and used S32 design studio IDE. I tried to configure portA and portc's pin out. found that portc c can be controlled by code. but port A pin did not work.  I debugged it, found that Port A PDOR is updated by code, but the real pin output status did not get change. so I want to check port A pin control register. but I did not know the port A pin control register base address. do you know what's the problem for port A did not work issue. and what 's the base address of port A pin control register?
2 回复数
2,945 次查看
danielmartynek
Which Port A pin do you mean?
Can you share the Port A configuration code.
Memory map is attached to the RM:
S32K1xx_Memory_map.xlsx
Port A 0x40049000 - 0x40049FFF.
But you can see Pin Control Registers in the S32DS.
2,945 次查看
weiqianglin
daniel,
got you。curently,all port A pins lost function while port B/C/D/E pins worked well。maybe port A is damaged。 but sadly,now I only had one pcb board。will get another board next week to verify。
Anyway,thank you very much!
weiqiang lin
