multi CAN bus on S32K148EVB
1,164件の閲覧回数
ken_wood
Can I set up the S32K148EVB for multiple CAN busses?
タグ(2)
2 返答(返信)
1,074件の閲覧回数
danielmartynek
Hi ken.wood@craneae.com,
There is only one CAN transceiver on the board.
If you need to connect the MCU to two separated CAN busses, you need to add an external transceiver for the second bus.
BR, Daniel
1,074件の閲覧回数
ken_wood
Thank you
Ken Wood | Software Engineer | Crane Aerospace & Electronics
16700 13th Avenue West, Lynnwood, WA 98037 | +1 425 743 8363 | F: +1 425 743 8540
