how to make a easy delay function by using the S32K144EVK board.
1,830 次查看
Guofred
i want to make a easy delay function for the blinking LED, i found this function doesn't have execute and  jump the code end line. the details as below.
the attachment is the source code, would you like kindly help to share your comments or provide your blinking LED code for reference, thanks.
Best regards.
Guofred
1,803 次查看
Senlent
Hi@Guofred
please refer to belowing picture.
BR!
     Jim,
4 回复数
1,820 次查看
Senlent
Hi@Guofred
you can take a look at belowing function
file osif.h
* @brief Delays execution for a number of milliseconds.
* @param[in] delay Time delay in milliseconds.
void OSIF_TimeDelay(const uint32_t delay);
BR!
     Jim,
1,811 次查看
Guofred
Hi @Senlent ,
Thanks for your kindly help.
would you like kindly help to share your code for reference, may be osif.h and osif.c are need to add our project, i can't use this function directly, thanks.
Best regards.
Guofred
1,804 次查看
Senlent
Hi@Guofred
BR!
     Jim,
1,790 次查看
Guofred
Hi @Senlent ,
Thanks for your patience and kindly help.
Best regards.
Guofred
