i want to make a easy delay function for the blinking LED, i found this function doesn't have execute and jump the code end line. the details as below.
the attachment is the source code, would you like kindly help to share your comments or provide your blinking LED code for reference, thanks.
Best regards.
Guofred
已解决! 转到解答。
you can take a look at belowing function
file osif.h
* @brief Delays execution for a number of milliseconds.
* @param[in] delay Time delay in milliseconds.
void OSIF_TimeDelay(const uint32_t delay);
BR!
Jim,
Hi @Senlent ,
Thanks for your kindly help.
would you like kindly help to share your code for reference, may be osif.h and osif.c are need to add our project, i can't use this function directly, thanks.
Best regards.
Guofred
