about Entire FlexNVM used to backup EEE data
449 次查看
teddywang
hi all
   The s32k144's Entire FlexNVM has been used to backup EEE data,whether could read the D-FLASH data by PE debuger? thanks
421 次查看
Senlent
Hi@teddywang
When you partition the entire FlexNVM space as EEPROM backup, it means that there is no D-FLASH, only E-FLASH(EEPROM backup space).
The E-Flash  can only be accessed through FlexRAM(EERAM).
if part of FlexNVM is partitioned as D-Flash and the other part is partitioned as EEPROM backup(E-Flash),then D-FLASH can be accessed normally by the debugger.
419 次查看
teddywang
OK,THANKS
