Why is the data received by LPSPI from the slave out of order?
1,476 次查看
kalvin
One of the two MCUs is the master and the other is the slave. The master starts DMA sending/receiving every 5ms and triggers the slave to start DMA receiving/sending through the external interrupt signal (IND).
void MainFunctionRun(void)
if(!Task_Delay[0])
Task_Delay[0] = 5; //loop every 5ms
SpiMaster_EmitInd(PTE,IND);
DMA_Start(SPI_DMA_RX_CH,SPI_DMA_TX_CH); //master start DMA for spi
void PORTE_IRQHandler(void)
if(((PTE->PDIR >> IND) & 1) == 0) //slave received IND signal
DMA_Start(SPI_DMA_RX_CH,SPI_DMA_TX_CH); //slave start DMA for spi
else if(((PTE->PDIR >> ACK) & 1) == 0) //no use
PORTE->ISFR |= (1<<IND)|(1<<ACK);
5 回复数
1,451 次查看
davidtosenovjan
Such effect are usually caused by overflow/underflow condition. How you are triggering DMA transfer on the slave side?
1,435 次查看
kalvin
In the above code fragment PORTE_IRQHandler, before the master DMA starts, the IND signal will be sent to the slave to trigger the slave DMA reception.
1,415 次查看
davidtosenovjan
It is unusual approach. It is needed to route DMA request directly from LPSPI to DMA module (with using of DMAMUX)
1,360 次查看
kalvin
@davidtosenovjan any new answers ?
1,397 次查看
kalvin
I also used DMAMUX @davidtosenovjan .
static void DMAMUX_Init(LPSPI_Type *Instance,uint8_t rxch,uint8_t txch)
uint32_t DMA_CH_RX_MUX_NUM = 0;
if(Instance == LPSPI0) DMA_CH_RX_MUX_NUM = 14;                                //using LPSPI0
if(Instance == LPSPI1) DMA_CH_RX_MUX_NUM = 16;
if(Instance == LPSPI2) DMA_CH_RX_MUX_NUM = 18;
SIM->PLATCGC |= SIM_PLATCGC_CGCDMA(1);
PCC->PCCn[PCC_DMAMUX_INDEX] |= PCC_PCCn_CGC_MASK;
/* DMA Channel 4 for LPSPI RX */
DMAMUX->CHCFG[rxch] &= ~ DMAMUX_CHCFG_ENBL(1);
DMAMUX->CHCFG[rxch] |= DMAMUX_CHCFG_SOURCE(DMA_CH_RX_MUX_NUM); //14
DMAMUX->CHCFG[rxch] |= DMAMUX_CHCFG_ENBL(1);
/* DMA Channel 5 for LPSPI TX */
DMAMUX->CHCFG[txch] &= ~ DMAMUX_CHCFG_ENBL(1);
DMAMUX->CHCFG[txch] |= DMAMUX_CHCFG_SOURCE(DMA_CH_RX_MUX_NUM+1); //14+1
DMAMUX->CHCFG[txch] |= DMAMUX_CHCFG_ENBL(1);
