Where can I get a debug application of OpenSDA for S32K144 EVB
1,957 次查看
maxmathew
I have a S32K144 EVB,I checked the version of its bootloader, it is 0201. Where can I get debug application for OpenSDA. I have downloaded DEBUG-FRDM-K64F_Pemicro_v108a_for_OpenSDA_v2.0.bin, but it seemed not work.
I am also confused for the volume of my bootloader, it only 128KB, but MSD-DEBUG-EVB-S32K144_Pemicro_v119.SDA is 144KB, I can not drag it to the bootloader.
4 回复数
1,427 次查看
lukaszadrapa
you can download it here:
http://www.pemicro.com/downloads/download_file.cfm?download_id=378
Notice that you must be registered on Pemicro. There's also document which describes how to update the firmware.
Lukas
1,427 次查看
maxmathew
Thanks for your answer !
What should I do if I want to use MSD?Because it seem the volume of bootloader is less than the firm's.
1,427 次查看
lukaszadrapa
It doesn't matter. Just follow attached procedure and it will work...
Lukas
1,427 次查看
maxmathew
Ok!  Thanks!
