Usage of CSE to implement AES128
kavithakakarla
hi,
I am planning to use S32K144 controller for one of our projects.
We have AES128 Algorithm to be implemented in the project. I understand, CSE is available in S32K144 and same can be used for implementing AES128.
But could not find much info on how to use this. Please let me know if any application note available that explain the usage of CSE for implementing AES128 algorithm.
Thanks.
884647067
Hi, I clicked and found out the link is not working anymore, can you share a working link again?
884647067
你好,我点击后发现链接失效了,你能再分享一个有效的链接吗?
danielmartynek
Please refer to AN5401 Getting Started with CSEc Security Module
AN5401SW.zip contains an example Code for AES-128 Encoding and Decoding
Jack7
Dhwani
I cant open the link provided here. pls share the correct link
When I click this link: AN5401 Getting Started with CSEc Security Module or AN5401SW.zip System gives below response.
ummerkunnummalk
Hi danielmartynek,
      In the sample code, the key counter and attribute flags are being bit shifted before loading into PRAM for calculating M2. Could you please explain this? Can you please guide me to any documentation with respect to this?
sudarshankumar
I tried using the above sample code.I am using Configuration of CSE module in S32K144 and also on S32K148.
After program partition command execution i see below behavior
1. ACCERR bit set
2. FCNG->EEERDY bit is not set
using same code as provided.
Tried other command 0x41 which is working fine.
Can you please tell me any modification is required for the sample code or any other checks needs to be done.
There is an reset happened after complete run is executed in debugger.This is happening while waiting for CCIF bit to set after command execution.Reset register indicate Core Lockup issue.
Sudarshan
danielmartynek
Do you run the examples from RAM?
sudarshankumar
Hi Daniel,
I tried to run it in RAM, core lockup is not happening, but i could see ACCERR bit is always set after Partition request and
Sudarshan
veronicavelciu
Hello Sudarshan,
Could you please check if the device you are using has security support, by checking the value of the SIM_SDID register?
Veronica
sudarshankumar
Hello Veronica,
SDID register is returning 0 value after reset and if am in break point read is not possible(Embsys register read).
I have question partition command has any dependencies if device supports CSE or not.
Sudarshan
veronicavelciu
Hello Sudarshan,
Program partition command should work even if the device does not support CSEc, but the CSEc Key Size parameter of the command must be 0 in this case.
Veronica
sudarshankumar
Hi Veronica,
Now i got Q100 EVB and i ran only partition command and i could see partition is happening EEERDY bit is set also Secured.
After reset i am not able to connect debugger, looks like controller is locked.
I tried Emergency Kinetics Device Recovery by Full Chip Erase
Can you tell me how can reset it to unsecure mode
veronicavelciu
Hello Sudarshan,
Could you please explain exactly the steps you followed? Did you run an Erase All Blocks command prior to running the Program Partition command? Did you run Program Partition command using 0 for CSEc Key Size?
Veronica
sudarshankumar
Hi Veronica,
Main function i ran below code
1. Erase all block (0x44)
2. Program Partition Command (0x81) with key value 03(20 keys)
3. Checked in while for security enable was success
Now debug access is not possible, RESET LED is continuously to ON.
I could see start up file has below values assigned and section start address is 0x400
/* Flash Configuration */
.section .FlashConfig, "a"
.long 0xFFFFFFFF /* 8 bytes backdoor comparison key */
.long 0xFFFFFFFF /* */
.long 0xFFFFFFFF /* 4 bytes program flash protection bytes */
.long 0xFFFF7FFE /* FDPROT:FEPROT:FOPT:FSEC(0xFE = unsecured) */
I am using S32K144EVB Q100 board
By using MDM-AP register is it possible to set mass erase or "flash from file" option can help?
Sudarshan
veronicavelciu
Hello Sudarshan,
Please check the following note from the RM:
So, the flash configuration field you mentioned in your comment, would need to be written immediately after step 1 (erase all block), otherwise the chip will be secured after the next reset.
Considering the attached note, mass erase will not work anymore.
I would recommend using the csec_keyconfig example in the S32 SDK, which shows how the Flash should be partitioned for CSEc usage.
Veronica
sudarshankumar
Hi Veronica,
Currently my EVB board i am not able to connect to debug mode, Is there any way i can execute mass erase.
Like trying JFlash tool to erase.
I checked for 1_Configure_part_and_Load_keys code and did same steps.
1.Only they do addition is load keys.
2.Erase All Blocks I have added extra before Partition.
Through EVB S32K144 SWD connector can i connect and debug?
Sudarshan
