The pins in SWD are inadvertently set to normal GPIO
668 次查看
jinsheng20
 s32k116
  • The pins in SWD are inadvertently set to normal GPIO.
  • Now I can't download the program through JLink. I only have JLink on hand. What should I do to resume downloading?
652 次查看
danielmartynek
You need to halt the program before the pins are reprogrammed to GPIOs.
There is PE Micro Kinetis Recovery Utility described here:
https://mcuoneclipse.com/2013/06/16/bricking-and-recovering-frdm-kl25z-boards-reset-swd-clock-and-lo...
With J-link, I haven't tested it, but I think you can try this:
Connect reset_b pin to the ground and power-cycle the MCU.
While the MCU is in reset, use J-link commander and the 'unlock kinetis' command.
