Dear NXP Engineer,
I have installed S32DS for ARM V2.2 (Windows), and now when I compile the project, I see a warning message in the Problems panel:
Description Resource Path Location Type The hardware settings required for project 'FLCM_4CH_S102' not found. FLCM_4CH_S102 FLCM_4CH_S102 S32 Project Version Problem
Could you please tell me what the problem might be, how I can fix it, and what potential project risks there might be?
解決済! 解決策の投稿を見る。
please take a look this article to help you to troubleshoot your problem
抱歉可能需要再麻烦您一个问题,我当前用得环境是S32DS V2.2,我发现无法自动编译组件,且无法加载路径。
Hi@GAC-Lamp-Knight
“'FLCM_4CH_S102”该工程你是导入至你的IDE中的还是直接复制到你工程目录下的?
请使用导入(import project)然后再测试下是否还有该问题。
如果不行,我需要你提供下工程,可以私发给我。
