Hello ,
i am using s32k144 on a custom board for motor control application. For Flashing the chip do i need any other software other than the S32 Design studio with the multilink usb debug probe .Do i require any separate software?
Also there are 2 variants available for the multilink , USB-ML-UNIVERSAL and USB-ML-UNIVERSAL FX.Is the USB-ML-UNIVERSAL be sufficient for s32k144?
已解决! 转到解答。
The mentioned equipment is enough.
You can use both (select by your priorities - compare features and prices):
Or better …directly www.pemicro pages https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320180&productTab=3
If you are searching for standalone possibilities then you can go to:
https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320169&productTab=3
Ladislav
