I'm using S32K148 controller. I want to send a 8 bit signed integer (-128 to +127). But the data type required for FCAN Send block in NXP MBDT accepts only uint8 datatype.
Just wondering if there is any way to send signed integer over CAN ?
Thanks in advance for your help.
"Just wondering if there is any way to send signed integer over CAN?"
No, this requires you to define some transmission rules yourself.
for example:
