SWD pins and reset_b pins of S32K146 are configured as normal IO.
617件の閲覧回数
ananan
SWD pins and reset_b pins of S32K146 are configured as normal IO. How do I recover it?
606件の閲覧回数
Robin_Shen
Hi ananan,
Seems that you already refer to the discussion in https://community.nxp.com/t5/S32K/Open-SDA-P-amp-E-Error/td-p/1497523
Did you download the Kinetis_Recovery_Utility.zip from there? PEMicro USB Multilink Universal Rev C should able to use to test. But please update it's firmware first.
Robin
5 返答(返信)
614件の閲覧回数
ananan
607件の閲覧回数
Robin_Shen
Hi ananan,
Robin
590件の閲覧回数
ananan
I solve the problem when I connect the TVCC pin,thank you very much!
592件の閲覧回数
ananan
I usethe three pins, DIO pin, CLK pin,GND pin。
599件の閲覧回数
ananan
I power board by hands cycling,but it does   not operation successfully
