S32k1xx Dflash and Eflash cycle durability
ZEROOO
    I would like to ask if Dflash is used as EEPROM backup by command, EEPROM backup is not addressable, this should be an EEPROM storage solution provided by NXP. When using EB's EEPROM storage strategy recently, it was discovered that Dflash can be addressed, and I guess they are just using Dflash as normal data flash.
    Question 1. If the Dflash area is not addressable, it indicates that Dflash is used as EEPROM backup. Please help me confirm this.
    Question 2. How to complete EEPROM page turning in E-flash according to the policy provided by NXP? Where is the introduction of this?
    Question 3. When Dflash is used as EEPROM backup and ordinary flash, is the cycle durability 100K and 10K respectively?
lukaszadrapa
Hi @ZEROOO
- Correct.
- This application note describes EEE functionality in detail:
https://www.nxp.com/docs/en/application-note/AN11983.pdf
- Cycling endurance of normal PFlash or Dflash is 1K cycles:
If DFlash is used for Emulated EEPROM, the flash controller uses slightly different handling and it's able to achieve higher endurance. The spec show 100K or 1.6M depending on the ratio to FlexRAM.
The best way is to use this calculator:
https://www.nxp.com/downloads/en/calculators/FME-Calculator.zip
Lukas
lukaszadrapa
Hi @ZEROOO
- Correct.
Lukas
