S32K412_HARD FAULT issue
gowtham1
Dear NXP,
1. I am flashing my .srec file using J Flash Lite its giving proper output.
2. now I am flashing .elf file in debug mode its going Hard fault.
could you please provide the solution ?
to fix above scenario I am using below steps :
1 Flash different Version of working SW and give power on reset.
2.now flash the issue elf file , able to debug and not going for Hard fault.
I am not getting what is the problem, please provide the solution
Gowtham K
