S32K314 How to use FreeRTOS in IAR?
737件の閲覧回数
Faith-Herio
#S32K3I used S32DS3.5 to establish the IAR compilation project, added the FreeRtos plug-in, and synchronously replaced the GCC file in the "protable" directory with the IAR file
but this error occurred during the compilation
Error[Lc036]: no block or place matches the pattern "ro code section CODE in portasm.o symbols: [PendSV_Handler, SVC_Handler, vPortStartFirstTask, vPortEnableVFP]"
616件の閲覧回数
sobo
I don't used S32 workbench, but to link FreeRTOS in S32K3 project we must add a section in the icf file provide by NXP.
/* Add section CODE for FreeRTOS */
define block codeBlock with fixed order { section .text, section .mcal_text, section .acmcu_code_rom, section CODE };
Sophie
5 返答(返信)
617件の閲覧回数
sobo
Sophie
706件の閲覧回数
jiri_kral
did you started the new IAR project from scratch or you switch toolchain in an existing project?
If you switched toolchain, try to create new project and in project wizard select IAR.
622件の閲覧回数
Faith-Herio
Is there a solution now?
703件の閲覧回数
Faith-Herio
I found that after adding FreeRTOS component, the Protable file added in the project was adapted to GCC version instead of IAR version. After I replaced the adapted file of IAR version, this problem occurred in the compilation, and I suspected that the "icf" file generated when building the project lacked support. If necessary, I can upload this file or project.
Thinks!
704件の閲覧回数
Faith-Herio
New project
