S32K312 flexcan example not running on Power reset
1,234 次查看
Adrish
We want to send CAN messages periodically. I am using the FlexCAN example for RTD 3.0.0. Additionally, i have configured a PIT timer so that I call the Flexcan_send periodically.
The code is building and running fine, but when I do a power reset on the board, the messages only come for a few seconds and then the code gets hanged.
I am using the S32K312 board with RTD 3.0.0.
Need support.
Attaching the example code for reference.
1,154 次查看
PetrS
just set divider to /2
BR, Petr
6 回复数
1,201 次查看
PetrS
setting HSE_clk to 60MHz would work.
BR, Petr
1,172 次查看
Adrish
Hi @PetrS
Can you please explain how to set this clock at 60 MHz. At present I see it set at 120 MHz.
I tried to change the frequency using the graphical tool inside the IDE but it showed me an error.
I'm using s32ds3.5
1,155 次查看
PetrS
BR, Petr
1,049 次查看
Adrish
Hi @PetrS . I tried the solution you suggested. It seemed to work initially but again the same issue was faced numerous times. After some investigation we found that the watchdog was enabled by default. Disabling the watchdog seemed to have fixed the issue completely.
Thank you for your support.
1,195 次查看
Akhil1
Hello @PetrS ,
Thanks...Its worked for me!!!
1,215 次查看
Akhil1
I am also facing the same issue with 3.0.0 version, but I think it will work for 2.0.3
If you find any solution with 3.0.0 version...let me know.
