Hello
If an exception occurs during operation, exception handling will be triggered. I want to get the trigger source of the triggered exception in exception handling, such as the address that triggered the exception. How to get it?
BestRegards,
Simon
Solved! Go to Solution.
As for documentation/guidelines available under the S32K product, we are not seeing anything on regards of the second point. Since this does not seem dependent on S32K or NXP, we can recommend looking into the available information outside of NXP, like the link below:
How to debug a HardFault on an ARM Cortex-M MCU | Interrupt (memfault.com)
Again, this is outside of the available NXP documentation, but there should available information on other sites. We do apologize.
Please, let us know.
You are referring to knowing the specific address in which the exception was triggered, is this correct?
If so, Is this under a debug session? Or under which conditions?
Hello @Daniel-Aguirre
1. Yes, I'm referring to knowing the specific address that triggers the exception. For example, if an out-of-bounds situation occurs in a function and an exception is triggered, I want to know the address of this function.
2. Not under a debug session, I'm referring to knowing the specific address under normal operation and then print it through the serial port or record it in DataFlash.
BestRegards,
Simon
