S32K312 How to configure the core clock to 3MHz in StandByMode
1,012 次查看
Simon-Liu
Contributor V
Hello
I saw in the S32K3xx Low Power Management.pdf that there is such a description in the [6.3. VLSR mode entry] chapter [FIRC must be divided by 16 to provides a 3 MHz clock source for the core, the bus, the peripheral clocks and flash memory access mode (750 KHz).].
I use the DS tool to configure a clock tree different from RUN Mode, which uses FIRC as the clock source, but the FIRC clock cannot be divided by 16 to assign to CORE_CLK, and the value of clock division is at most 8.
How to divide FIRC into 16 when entering StangBy?
BestRegards
904 次查看
davidtosenovjan
Click on Fast RC, an on the right side you may choose a frequency.
6 回复数
983 次查看
davidtosenovjan
Hi, could you give me reference to S32K3xx Low Power Management.pdf?
981 次查看
Simon-Liu
Contributor V
Hi @davidtosenovjan
Please use the attached document
944 次查看
davidtosenovjan
Following register allows to setup FIRC divided by 16:
941 次查看
Simon-Liu
Contributor V
Hi @davidtosenovjan
Thanks for your answer, can you please tell me how to configure this register using DS tool?
BestRegards
905 次查看
davidtosenovjan
902 次查看
Simon-Liu
Contributor V
Hi @davidtosenovjan
Thank you very much for your answer, I understand.
BestRegards
