S32K312 DMA + IDLE cannot receive data after printing.
li3
Hi NXP,
    S32K312 uses DMA to receive data, define an array RXBuffer to store data, I found that as long as the RXBuffer data is printed, the RXBuffer array will not receive new data, please ask NXP why?
    However, after I have defined the RXBuffer array into non-cacheable memory, the RXBuffer array can also receive new data after printing the data in the RXBuffer array. Please tell me the reason in detail, thank you.
    I checked the post below, but I don't understand why. Please elaborate on that.
https://community.nxp.com/t5/S32K/The-S32K312-UART-DMA-IDLE-No-matter-which-UART-sends-data-is/m-p/1...
Best  Regards,
Li 3
Julián_AragónM
Hi @li3,
when working with UART and DMA, the MCL Integration Manual (RTD_MCL_IM.pdf) states that the Rx and Tx buffers should be allocated in the NON-CACHEABLE area, and that the addresses of Tx and Rx message transmit via DMA should be 32-byte aligned.
This is due to cache coherency problems when D-CACHE is enabled.
Julián
