S32K3
S32K3
youxi
Hi:
If the S32K312 application is in block0. Will the application not be able to erase sectors in block0? The flash operation is already in RAM
danielmartynek
Hi @youxi,
The Block 0 must not be accessed by any master during a flash operation on that block.
The code (in SRAM or another block) that launches the flash operation must not read any data from Block 0.
If interrupts stay enabled, the vector table, ISRs, and the data that the ISRs read must not be in Block 0.
BR, Daniel
