S32K3 After the variable changes the section attribute, the text section compilation is problematic
349件の閲覧回数
OCEAN_CEC
I am using s32k311 to complete the function of SPI+DMA communication, I tried to put the buff into the no_cache area, after compiling, I found that the link symbol _text_end ran to the ram area, I don't know if I made something wrong, could you give me some suggestions, thank you!
5 返答(返信)
317件の閲覧回数
danielmartynek
Hi @OCEAN_CEC,
Can you share the project?
Do you have a screenshot of the error message?
What RTD and compiler version do you use?
309件の閲覧回数
OCEAN_CEC
compiler :gcc-10.2-arm32-eabi
RTD: R21-11_3.0.0_P07
HW :S32K310
I discovered the problem when the program ran away,compile without errlog.
275件の閲覧回数
danielmartynek
Hello @OCEAN_CEC,
Can you read the .map file and confirm the variables are correctly placed in the sections?
Is the MPU descriptor correcly configured at the section in system.c?
236件の閲覧回数
OCEAN_CEC
Hi  Daniel
   Thank for your reply.
   I read system.c and.map, and this variable is actually placed in the area I want. Currently, the MPU is configured using the default project configuration. In my understanding, this should not affect the address of the link symbol.
228件の閲覧回数
danielmartynek
Hi @OCEAN_CEC,
Please share the project so that I can test it.
If you don't want to share it here, create a ticket.
