S32K1XX单片机中,在IDE中调试时pause后,停在 DefaultISR: b DefaultISR
642142357
S32K1XX单片机中,在ide中调试时pause后,停在
                    .size DefaultISR, . - DefaultISR,怎么解决,怎么查?thanksconstantinrazvan.chivujimtrudeauS32 Design Studiojcrannell-ash@vanteon.comreneeamossberg-r2388ckhumphridhavaljimtrudeau
vicentegomez
Hi, can you help me to put your question in English
Thanks in advance
razva_tilimpea
In 90% of cases the root-cause for this error is the lack of clock source. Please go to clock manager component and enable clock sources for all peripherals used in your application.
Razvan
pjzmj2012
hi,can you put you picture in here.We don't know where clock manager component is it.
你能放张图片上来说下你说的功能是在那个菜单下面吗?
642142357
S32K1XX mcu,progamg in  the ide running pause后,停在
