Development of FS32K118LFT0MLHT.
Using keil and jlink simulation,can normally erase and download programs.
Now use jflash and jlink,often prompted for erasure failure,then it's impossible to connect,part of the board holds the reset and can be connected.
Such problems occur frequently,what is the cause of the erasure failure?
Hello zhangzhiyong@zlgmcu.com,
Since you don't have any problem with KEIL + J-link but with J-Flash + J-link, please contact SEGGER support:
https://www.segger.com/support/technical-support/
Thank you,
BR, Daniel
