S32K144: HOW CAN DMA TRIGGERED BY TRGMUX?
599件の閲覧回数
Yang123
I face some problems about using DMA to change PWM.But i do not know how to trigger the DMA periodically.I found we can use TRGMUX, But i do not found some example project or code. So, please give me help.
6 返答(返信)
587件の閲覧回数
petervlna
You can use direct DMA trigger from FTM as reference manual express:
The available example SW is in SDK package:
I am not fmailiar with those examples, but I see some FTM interrupt ones, which after slight modification according to above can be used to trigger DMA.
best regards,
Peter
580件の閲覧回数
Yang123
The requriment that i need use DMA to control the FTM register then change the PWM output.So I need use orther register to  trigger the DMA.
566件の閲覧回数
petervlna
On which event you need to use DMA to configure FTM?
Peter
562件の閲覧回数
Yang123
hello
Actually, I need use DMA to carry an array to FTM,Then use cnv and cncs register to change the PWM. But How to trigger the DMA prodically is the problems i am facing.
I find DMAMUX can triggered by TRGMUX, So i want to know how to use DMAMUX and TRGMUX。
best wishs
Yang
542件の閲覧回数
petervlna
Yes, that is correct.
In order to understand your requirement, on which event you want to trigger DMA via TRGMUX?
On some ADC done conversion? PWM period reload? or just simple periodic trigger every time interval? etc...
Peter
140件の閲覧回数
rachel3
I am having the same issue and want to trigger every period of the FTM PWM output.
