S32K144 Departition for Csec
851件の閲覧回数
XueZheng
I have encountered problems during trying to enable the Csec feature on S32K144, and to do so, the first step I tried is to partition the flexNVM to 32K/32K and I found out that when the FCCOB1 is set to non-zero while the rest of FCCOB is set to exact same as Figure 5 in AN11983, then the operation is failed with FSTAT->ACCERR set.
For your information,
  1. This departition command is executed from RAM
  2. The Interrupt is suspended before executing this command
  3. Erase all blocks command and Program the secure field (0x40C) have been executed successfully before this command
  4. When the FCCOB1 is set to zero, the rest code is unchanged, then this command will be successful
831件の閲覧回数
XueZheng
@lukaszadrapa  thank you, after checking, the order information of MCU I used is S32K144HFVLH and the 'F' indicates "CANFD FlexIO" without security. I guess the higher version MCU of the S32K144 needs to be used to enable the Csec
2 返答(返信)
836件の閲覧回数
lukaszadrapa
this is working on my side. Which part number do you have exactly? Could you confirm it is device with CSEc?
or if you have older device:
Lukas
832件の閲覧回数
XueZheng
