S32K118的pflash和dflash如何使用
239 次查看
Vapaus
S32K118的pflash和dflash如何配置并且使用
212 次查看
Julián_AragónM
Hi @Vapaus
You can find some flash examples inside the Real-Time Drivers (RTD) package.
To install this RTD version you need to download the UpdateSite.zip file from the flexera portal. Once you have it, at S32DS Extensions and Updates, click "Add Update Site" and select the zip file, then click Open, you need to select the file and then Install.
Julián
213 次查看
Julián_AragónM
Hi @Vapaus
Julián
