S32K TRGMUX I don't understand trgmux_in0~trgmux_in10
809件の閲覧回数
LijieDu
As shown in the above figure, I don't quite understand trgmux_in0~in10 and trgmux_out0~out10.
Does anyone can provide some docs to learn?
タグ(1)
786件の閲覧回数
Senlent
Hi@LijieDu
you need to read S32K-RM -> Chapter 19 Trigger MUX Control (TRGMUX) for more detail.
5 返答(返信)
787件の閲覧回数
Senlent
Hi@LijieDu
727件の閲覧回数
LijieDu
@Senlent Thanks!
But I still don't know how to make the trgmux_in4 as a valid signal to trigger lpit ch0.
712件の閲覧回数
Senlent
Hi@LijieDu
There are the following routines in the IDE, you can refer to this routine for modification, this is very simple, almost no need for users to modify the code
696件の閲覧回数
LijieDu
@Senlent Thanks!
I Saw it yesterday, and it run as you said.
Also, when I  shorted PTD3 to 5V, the lpit ch0 interrupt will also be triggered, So trgmux_in4 is enabled when there is a rising edge on the pin PTD3, right?
689件の閲覧回数
Senlent
