S32DS for ARM v2.2 installation stopped processing after putting activation license to popped java window, I tried many ways such as offline mode ,release more space for installation, reboot window10 computer , all result in the same phenomenon as the picture showed installation process stoped without any prompt. Could someone suggest other ways of solving this problem. really appreciated!
Solved! Go to Solution.
By first installing S32DS for ARM 2018R1 then install the version 2.2 ,the problem solved !
