S32DS 3.4导入adc_example_s32k118编译失败
956件の閲覧回数
yshenu
make: *** [src/main.o] Error 1
make: *** 正在等待未完成的任务....
In file included from ../Project_Settings/Startup_Code/exceptions.c:30:
/home/xysun/NXP/S32DS.3.4/S32DS/software/PlatformSDK_S32K1_2022_02/SW32K1_RTD_4_4_1_0_1_D2202/Base_TS_T40D2M10I1R0/include/Mcal.h:62:10: 致命错误: Soc_Ips.h:没有那个文件或目录
62 | #include "Soc_Ips.h"
编译中断。
10 返答(返信)
744件の閲覧回数
Senlent
Hi@yshenu
For your new question:"The window installation is OK, but the Ubuntu installation fails. I can't found reason"
Could you please create a new topic , because I know nothing about Ubuntu.
777件の閲覧回数
yshenu
945件の閲覧回数
Senlent
Hi@yshenu
please click "Update code" to generate config file before building it.
941件の閲覧回数
yshenu
Hi Senlent
Already updated, but still the same problem
934件の閲覧回数
Senlent
Hi@yshenu
According to the log file you provided, the Soc_Ips.h file is missing from your current project, but in fact the file will be generated in your project directory after you update the code. So my conclusion is that you probably didn't generate the configuration code correctly
923件の閲覧回数
yshenu
Hi senlent
Maybe the component function does not exist. How to install this function?
919件の閲覧回数
yshenu
Hi senlent,
912件の閲覧回数
Senlent
Hi@yshenu
please show me your S32 DS version like picture below, you can see the RTD 1.0.1 require "Update 1" and above version installed.
910件の閲覧回数
yshenu
Hi senlent
look,version is ok
907件の閲覧回数
Senlent
Hi@yshenu
I can't think of other possible reasons. I can only suggest that you reinstall the IDE and RTD. Try not to use Chinese and try again.
